6 Ways the RF540N4WF1 Keeps Your Food Fresh
09.04.2024
 Is there anything worse than going to get something from the fridge that you’ve been waiting to use, only to see it looking limp and worse for wear? Keeping food fresh can be hard but the RF540N4WF1 has amazing features all designed to keep your food fresh for longer. Here are 6 wonderful ways the RF540N4WF1 can keep your food fantastically fresh this springtime!
Total No Frost
  1. The RF540N4WF1 comes with Total No Frost, and with this smart tech an optimum temperature is maintained in the fridge freezer at all times. This helps prevent frost from forming and spoiling food, helping keep it fresh for longer!
Multi-Air Flow
  1. Another fantastic feature is Multi-Air Flow. The key to keeping food fresh is consistent temperature and with Multi-Air Flow cold air is evenly distributed all around the fridge, so wherever your food is it will stay perfectly preserved.
My Fresh Choice Zone
  1. The RF540N4WF1 also comes with additional storage space with the My Fresh Choice Zone, which can effortlessly be converted from a fridge space to a freezer space. By allowing you to adjust the temperature from -18 degrees Celsius to 5 degrees Celsius, you can flexibly choose the best temperature to keep your food fresh.
Powerful Cooling
  1. Having quality tech on your side goes a long way in helping prolong your food and keep it tasting fresh, the RF540N4WF1’s Powerful Cooling keeps the fridge compartment at 2 degrees for 6 hours. Perfect for locking in all the flavour!
Durable Invertor
  1. The RF540N4WF1’s Durable Invertor works to keep everything stable and all the other great features working in harmony. It also makes the RF540N4WF1 extremely energy efficient which also helps save you money too!
Fresh Crisper
  1. Finally, the Fresh Crisper is the ideal space to keep all your fruit and vegetables intact, since the closed off area keeps them extra secure. The transparent design also helps you have full view of everything inside, so you don’t forget about them!
To learn more about all the ways the RF540N4WF1 can keep your food fresh just head on over to the website! Why not check all its other features too? Plus, there are a whole bunch of other fridges available to perfectly suit you needs whatever they may be, explore the whole range now on Hisense UK.
