QLED vs LED vs MiniLED vs OLED: What’s the Difference?
04.06.26
With so many new TV technologies to choose from, how do you know which will be the best for you and your home? Hisense has created a guide to help you understand the key differences between TV technologies and the acronyms we use to describe these technical differences.
| Technology | Best For | Brightness | Contrast | Colour | Burn-in Risk | Price |
| LED | Everyday viewing | Good | Standard | Good | Very Low | £ |
| QLED | Bright rooms & colours | Excellent | Strong | Excellent | Very Low | ££ |
| MiniLED | Premium HDR viewing | Excellent | Excellent | Excellent | Very Low | £££ |
| OLED | Cinematic Viewing | Very Good | Exceptional | Excellent | Higher Risk | ££££ |
What’s QLED?
QLED stands for Quantum Light-Emitting Diode. It's a type of LCD TV that uses a quantum dot filter — a layer of tiny semiconductor crystals — positioned between the backlight and the LCD panel.
These quantum dots are precisely engineered to emit specific wavelengths of light, producing a far wider and more accurate colour range than the standard RGB filters found in older LED TVs. The result is a brighter, more vibrant and more consistent picture — even at lower brightness levels.
Compared with standard LED TVs, QLED TVs deliver brighter colours, improved contrast and a more immersive viewing experience — especially when watching HDR content or viewing from wider angles.
QLED builds on LED technology rather than an replacing it entirely, which is why it can offer picture quality closer to more expensive alternatives at a more affordable price.
QLED is particularly well suited to:
- Bright rooms - high peak brightness cuts through glare with ease
- HDR and 4K content - a richer, wider colour makes every scene pop
- Gaming and sport - high refresh rates and low input lag keeps up with all the action
- Families and everyday viewing - a strong all-round performance at a range of price points
What is ULED?
ULED is Hisense's name for a group of TV technologies designed to improve picture quality. Together, they help deliver better colour, clearer motion, stronger contrast and sharper 4K detail than a standard LED TV.
ULED TVs offer a wider colour palette for more natural, lifelike images, improved local dimming for stronger contrast between light and dark areas of the screen, and motion enhancement technology that produces smoother fast-moving action — particularly noticeable during sport and gaming.
As a Hisense standard, ULED can be applied across different TV screens, meaning you'll find ULED combined with MiniLED backlighting and other advanced technologies across the Hisense TV range.
QLED vs ULED: What's the Difference?
The core difference between QLED and ULED is the quantum dot filter. Compared with standard LED TVs, which rely on conventional RGB colour filters, QLED offers a wider colour range. QLED's quantum dot layer also allows more of the backlight to pass through accurately, delivering:
- Significantly higher peak brightness
- A wider range of richer, more vivid colours
- Consistent colour, whatever the brightness
- Improved off-axis viewing — better viewing and picture quality from every angle
For most buyers, QLED represents the best balance of picture quality and value.
What is MiniLED?
MiniLED uses thousands of tiny LED lights (less than 0.2mm in size) behind the screen for far more precise brightness control. The result? Deeper blacks, brighter highlights and sharper contrast.
Pair it with QLED and its quantum dots, and you also get richer, more accurate colour.
MiniLED is particularly well suited to:
- HDR content - deeper blacks and brighter highlights improve every detail
- Home cinema - more depth, more detail, more drama
- Bright rooms - MiniLED's peak brightness maintains image quality
- Gaming - faster, brighter and more immersive play time
QLED vs MiniLED: Which is Better?
This is one of the most common questions in the premium TV market, and the answer isn't a simple either/or, because QLED and MiniLED are different types of technology that often work together rather than against each other.
QLED describes a colour enhancement layer (the quantum dot filter).
MiniLED describes a backlighting method.
Many of today's best-performing TVs use both: a MiniLED backlight for precise contrast control, combined with a QLED quantum dot filter for exceptional colour. In these cases, you're not choosing between them — you're getting the benefits of both.
If you're comparing a standard QLED TV against a MiniLED TV:
- MiniLED will generally offer better local dimming, deeper blacks and higher peak brightness
- Standard QLED may offer better value at a lower price point
- For HDR, home cinema and gaming, Mini LED's contrast advantage is tangible
- For everyday TV watching and bright rooms, the difference is less significant
The verdict: For premium HDR viewing and home cinema, MiniLED (especially combined with QLED) is the step up worth making. For everyday viewing and value, a quality QLED TV delivers excellent results.
What is OLED?
OLED stands for Organic Light-Emitting Diode. Unlike LCD-based technologies (LED, QLED, MiniLED and ULED), OLED panels don't require a backlight at all. Instead, each individual pixel generates its own light — and crucially, can switch itself off completely.
When a pixel is off, it produces zero light. This means OLED TVs can achieve true black levels, with no backlight bleed and near-infinite contrast ratios. The difference in dark scenes — cinema, drama, night-time sport — is immediately visible.
OLED also delivers excellent off-axis viewing, with colour and contrast remaining consistent even from wide angles.
The main considerations with OLED are:
- Burn-in risk: some static on-screen elements (like news tickers or game HUDs) can, over time, leave a faint image on the screen. Modern OLED screen technology is better than ever, with significant improvements made, but it should be a consideration for heavy gaming or news viewers
- Peak brightness: while OLED delivers exceptional contrast, the latest MiniLED TVs can exceed OLED brightness in very well-lit rooms
- Price: OLED panels remain at the higher end of the market
QLED vs OLED: Which is Better?
This is the question that generates more debate than any other in the TV world. Both are excellent, but they perform best in different environments.
Where OLED excels
- Dark-room, cinematic viewing — the contrast and black levels are genuinely exceptional
- Off-axis viewing — consistent picture quality from any angle in the room
Where QLED (and MiniLED) excels
- Brightly lit rooms — higher peak brightness means less washout from ambient light
- Sport and gaming — brightness, colour volume and fast response times are all strong
- Value — QLED delivers exceptional picture quality at a more accessible price
- Longevity — no burn-in risk with QLED's LCD-based panel
For most households, a high-quality QLED or MiniLED TV will deliver a superior everyday viewing experience. OLED excels in dedicated home cinema environments where lighting can be controlled.
The verdict: OLED is the choice for dark-room cinephiles. QLED and MiniLED offer exceptional brightness, colour and versatility for everyday viewing — and at a significantly lower price.
Which TV Technology is Right for You?
The right TV technology depends on how and where you watch:
- Bright living room, everyday viewing: QLED or ULED — high brightness and excellent colour handle ambient light well
- Premium picture quality, HDR and home cinema: MiniLED (ideally combined with QLED) — the contrast and brightness precision make a real difference
- Dedicated dark-room home cinema: OLED — exceptional black levels and contrast for film viewing
- Gaming: QLED or MiniLED — high brightness, fast response times and no burn-in risk
- Budget-conscious upgrade: QLED — a significant step up from standard LED without a significant price jump
Whichever direction you're heading, Hisense offers a range of screen technologies across all of these categories, designed around the way real people actually watch.
Frequently Asked Questions
Is QLED better than LED?
QLED delivers significantly brighter colours, improved contrast and a more consistent picture across all lighting conditions. For the majority of viewers, the upgrade from standard LED to QLED is well worth it — particularly if you watch a lot of HDR content or have a brightly lit room.
Is OLED better than QLED?
It depends on how you watch. OLED produces perfect black levels and exceptional contrast, making it ideal for dark-room, cinematic viewing. QLED and MiniLED, however, are significantly brighter and more versatile for everyday use in well-lit rooms. Neither is universally superior — it comes down to your environment and viewing habits.
Does QLED have burn-in?
QLED uses an LCD panel with a backlight — rather than self-emitting pixels — it is not susceptible to burn-in. This makes it a particularly good choice for use as a gaming monitor or if you regularly watch news channels with static on-screen graphics.
Is MiniLED the same as QLED?
No, though many premium TVs combine both technologies. QLED refers to the colour-enhancing quantum dot filter layer, while MiniLED refers to the backlighting method. A TV can use MiniLED backlighting with a QLED panel to deliver the benefits of both: exceptional brightness, precise contrast and vibrant colour.
Is OLED worth the extra cost?
For dedicated home cinema enthusiasts viewing in controlled lighting, OLED's picture quality is genuinely exceptional. However, for most households, a high-quality QLED or MiniLED TV will deliver a superior all-round experience at a significantly lower price — particularly in brighter rooms or for sports and gaming.
Find the Right Hisense TV for You
Whether you're looking for vibrant QLED colour, immersive MiniLED contrast, or an everyday smart TV that handles everything, Hisense offers the widest range of screen technologies designed to suit every way you watch.
Explore our QLED TV range or MiniLED TV range, or explore the whole Hisense TV range to find your perfect match
